Hi all im having 1 big nightmare and im hopin some1 out there can help me. What it is i have a bluetake (bluetooth) usb and i have the latest drivers install (Version:1.3.2.7 ) and i can send software etc from pc to 3650 without a problem but wen i try to send 3650 to PC nothin it comes up (unable to connect) i have also just install 3650 PC SUITE and that cant find my 3650, i read the help and it says make sure u have the correct COM but wen i looked in the device manager the ports my bluetooth device are using are 3,4,8,9,10,11,12,13 so in the MROUTER i selected them and still it cant find it, so i looked at my advanced config in the bluetooth and the local services the bluetooth serial port is on 10 and i looked in the client applications and the blue serial port is 11 so again im lost, in my bluetooth places i have only the OBEX FILE TRANS do i need more? anyway i hope u can undastand this and some kind person sort me out cheers all.
Ps i also read that somewere in the registry on my pc u need to check to see if a file reads 00000000.0 as it need to end with 0.1 but mine already does.
PPs Erm 76 Views and not 1 reply 😞
