Does anyone know how I find out my Blue tooth pass code so I can create a bond between my Phone and PC.
The passcode should be the same combination on numbers both for PC and Phone.IE:You type 123456 on the PC and then 123456 on phone.
it's also possible to just type one number eg enter "1" on the phone and "1" on the PC. If maybe you can't remember lots of number 😃 😃 😃 😃
thankyou very much problemo solved! Now do you reckon I can surf the web on my phone using the Lan on my pc at work?
In most cases it should work,if you have a working bluetooth adapted atached to a PC that has interent access.
Search the forum,its a widely discussed topic.
GhostDog's right. A really simple guide is:
Create a dummy bluetooth GPRS connection on your phone - access point name 'bt'.
On the PC, establish a connection to the phone using bluetooth and mRouter.
Once the connection is established, launch the app you want to connect through the LAN on the phone, and tell it to connect through the dummy bluetooth GPRS connection.
As far as I am aware, it is NOT possible to use 'Services' or RealOne Player through the LAN connection over bluetooth.
Cheers
