At risk of never being taken seriously again (like I ever was), I'd just like to point out that simeonbubblegum has an avatar that's almost as good as mine.
Avatars
hmm, not sure, that tractor is very tasty! 😎
Checkmine also...
Originally posted by TheSpecialBoy
Checkmine also...
Don't see anything wrong with it.... 😃
[actually, I dont see any avatar at your posts...]
How's my new one?
Originally posted by rb14If your avatar was made by yourself,you should ask those guy to change it.
Jimmy-floyd, you are soooooooo rude! That is my racecar. The one I built from nothing, engine, gearbox, suspension, everything. If you're not careful, I'll post a full-size pic of my second racecar.
Now behave yourself, you might be cute, but it doesn't mean you can get away with naughtiness!!!
In truth though, my original post referred to my other avatar, a tractor. Here is a pic:
Originally posted by rb14I just didnt know that it is your car.
Jimmy-floyd, you are soooooooo rude! That is my racecar. The one I built from nothing, engine, gearbox, suspension, everything. If you're not careful, I'll post a full-size pic of my second racecar.Now behave yourself, you might be cute, but it doesn't mean you can get away with naughtiness!!!
Can we post avatars bigger than 50x50 again yet?
The 80x80 was just s-o-ooo much better!
Yes.
They can now be 75x75 (as long as you have more than 50 posts).
OK so The Party Boy now has the best.
Yes.They can now be 75x75 (as long as you have more than 50 posts).
Ahhhh, yes.
Better. 😎
