Rudi Timmermans has released two small freeware utilities. Countdown is a simple count timer and Stopwatch is exactly what it sounds like.
Countdown is a small application that was coded in OPL on the Nokia 9210, you can use it when you need to reminder on some time, after the time is up running Countdown will give you a reminder beep signal.
Stopwatch is a small application that was coded in OPL on the Nokia 9210, sport people can use this small application to set the laps afther running or some other sports events.
[quote="Rafe"]Rudi Timmermans has released two small freeware utilities. Countdown is a simple count timer and Stopwatch is exactly what it sounds like.
Stopwatch is a small application that was coded in OPL on the Nokia 9210, sport people can use this small application to set the laps afther running or some other sports events.[/quote]
