P800 and bluetooth
3 replies · 1,470 views · Started 25 September 2003
Hello everybody...I developed a program for my P800.
The program is quite simple and perorms just a discovery of the bluetooth devices in the reachable area, but the midlet does not start....Symbian OS 7.0 should have jsr-82 integrated....am I right?
Can somebody help me?
Thanx
Wrong.
The P800 does not have JSR-82, MIDP 2.0, or any other decent thing to do with Java. J2ME on the P800 is quite simply... crap.
Ok,thanx for your reply...
I read that phones with symbianOS 7.0 all support java Bluetooth api....so that is not true....
So is there any other possibility to access the bluetooth stack on my p800???(using java...)
pizzo
SE will tell you that you can use JNI code with the PJAVA implemtation do access it, but I don't know anyone who has. So the answer is really no.
Only hope is a SE upgrade to UIQ 2.1 😊
