N-Gage on display at Canary Wharf
2 replies · 1,861 views · Started 26 September 2003
Not sure if anyone lives in East London but if you're interested they have 2 N-Gage's on display at the Carphone Warehouse at Canary Wharf. They've both got Pandemonium on them and you can play against the other via Bluetooth.
I didn't get a good look at them since I'd just popped out on my lunch break but my first impression was that they're smaller than I'd expected and te screen was pretty good.
Still not sure about using it as my primary phone or the fact that you have to remove the battery to chaneg game.
Yeah they have one in GameStation here in Newport thats running Tombraider. I had a 5 minute go and it's surprisingly easy to contol, having the autorun on actually saves you from holding down forward, and it's really smooth and pretty! I was also surprised at it's size and look, much smaller and better than I expected. Good luck to Nokia!
i went into the t-mobile shop in the Arndale Shopping Center in Luton and they have the same. i have a brief look and the screen quality is very good and is the size and build quality. i cud not look through the fone menu system as it only seemed to be set up as a "demo" mode for the games only..
anyone else had a look or try, let us know what u think
waks
