I have been trying to install the appforge booster but it just doesnt work.
It keep asking me what language to install that the blue screen appears then they ask what language again.
I am using a 128 mb memory stick duo so memory is not a problem.
can anyone help??
try downloading the booster again from the site ... or try installing in a different language ..
Originally posted by kennyseah17
I have been trying to install the appforge booster but it just doesnt work.It keep asking me what language to install that the blue screen appears then they ask what language again.
can anyone help??
There is only english language for selection
I have already solved the prob...
All you got to do is when they keep asking you to choose the language just choose ok..
This will have to be repeated for a few times and it will be installed.
one thing to note is the progress bar will never appear so don't think that there is something wrong with the installation file..
actually app forge installs 6 app. on your phone, so u still have to choose the language then ok 5 times till it gets installed completely on your device. they are:
app forge booster
app forge booster main
app forge booster modules
app registration service
fuser functions
owner drawingots
and if u r installing the full version, u'll get:
more apps
