is it possible to watch office docs with this OS on the 6600 ?
do i need a special software ? where can i get it ?
2. can i sync with outlook (contacts,calender,to do list ???)
thankxxx
thankxxx
There are applications such as RepliGo that can covert Microsoft Office documents to a format viewable on the phone. No built-in support for that.
With the Nokia PC Suite you can synchronize contacts/calendar/tasks with Outlook on a desktop PC using either infrared or Bluetooth.
There is QuckWord and QuickPoint for viewing Word and Powerpoint documents on series 60. You can find more info here.
Hopfully they will be providing more office support soon.
Sounds great with these apps. I have accually never heard of them before!
Hopefully XP compatibility in the near future!
Do tasks get synced?
The manuals doesn't say so. Just Contacts & Calendar....
Has anyone done this? My outlook express .WAB file and the contacts in the 6600 do not seem to synchronise. The PCsuite software goes through all the motions and then reports zero files updated.
Nothing changes on either pc or phone!
