Fax
2 replies · 1,300 views · Started 29 September 2003
May be there is a simple way of doing it ?
I'd like to send a fax to a fax number using say... a pdf file. Can I ? How ?
Thanks for your advice
You can't at present. P800 does not support fax as far as I know, and it isn't just a software thing, think you need some hardware to correctly modulate the fax signal.
Probably have someone who can be more specific come along and explain in a minute....
You are right. Actually P800 can be act as a fax modem too instead of sending and recive fax directly.
