6600 max MMC Card size.
13 replies · 12,503 views · Started 29 September 2003
As far as i know Nokia3650 has limited to 128mb mmc cards, what are the limit of 6600? Can i use SD cards? Can it use 256/512 mmc cards?
Post Preview:
I doubt it supports SD otherwise they would have said so.
All SD readers read MMC but MMC readers do not read SD.
It seems strange to me that they have adopted MMC for both Series60 phones and N-Gage. I had thought it was a dying format. It was first introduced in 1997 and was used in some early MP3 Players. The largest size at the beginning was 32Mb. I think Nokia should be using SD instead as it allow much larger capacities and transfer rates.
How many are there now?
Compact Flash Type1
Compact Flash Type2
SmartMedia
xD Picture Cards
Memory-Stick
Memory-Stick Pro
Memory-Stick Duo
MagicGate Memory-Stick
MMC
SD
The 3650 is not limited to 128 MB MMC's.Some brands of 512 and 256 MB MMC's do work with the 3650.You can search the 3650 forum for working brands.
I have read that the Tec MMC works fine on the 6600.
Heres the link of comany.
http://www.tecic.com.tw/English/AboutUS.html
Anyone tried 512MB this memory on 6600 yet?
I think thats the one that is being sold on ebay, cause the official website has a link( http://www.riogeo.biz/technology/technology.htm ) to buy from the uk(europe shipping) and looks the same like the one on the ebay listing( http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=3356829557&category=14408 )
Does anyone know if u can put a 1gb MMC card in your nokia 6600. If not what brands of 512mb MMC cards work in it.
Unregistered001 wrote:Does anyone know if u can put a 1gb MMC card in your nokia 6600. If not what brands of 512mb MMC cards work in it.
I heard many times of folks using the 1 gb MMC with the 6620. I decided to get one myself....will let you know if it works...
I have 512mb card in my N6600 and it fully works, 1gb maybe works too
I'm not sure but I think that most/some 1gb mmc works nearly in all nokia phones... At least I know that almost every nokia phone supports the 1gb, but the support for different mmc manufactures varies...so if the mmc manufacture doesn't say if the memory is supported find a merory that is...
