errr.. i just surf the net bout this and most sites shows that 9210(i) has 640 * 240 Pxl
but what i'm confused is when i resize a wallpaper it's xxx * 200 (full screen 640*200)
so which one is the correct one ??
you must use a image with the 72 dpi resolution
(usually used for web)
The 9210(i) has 640 x 200 pixels. If any website is saying something else, they are probably confusing it with its 'predecessor', the Psion 5mx, which has 640 x 240 pixels.
