Hi.
The product description talks about:
Automate the keylock function to enable the keyboard to lock automatically on closure thereby bypassing the annoying �Lock Keypad? message.
Does anybody know how to implement this?
Thanks...
Hi.
Thanks...
Hi Ray,
You can enable/disable this function from Options->Setting->System->Auto Key Guard in Ximplify SeleQ
If you set it to "On" (default setting), the keylock activates whenever you close the Nokia 7650 and deactivates when you slide-open the phone.
Cheers
Patrick
Thanks,...but unfortunately this does NOT seem to work.
Can this be due to the installation of TaskManager???
I know the option in TaskManager does work, but before I installed it I tried to use SeleQ to control this, didn't seem to work.
I'm using Task Manager and SeleQ and it seems when opening SeleQ the Task Manager gets closed automatically ... kind of strange.
Another problem with Task Manager is that the command "close all task" does not seem to work - it tries to close the "phone"-task too which obviously cant work and hangs.
