MemoryImageSource on P800
0 replies · 963 views · Started 01 October 2003
Hi!
I'm experiencing some problems while using the MemoryImageSource on my P800. I first draw onto an image, then I use the PixelGrabber and an algorithm to rotate the pixels (I want to use the display "sideways"😉. This is the code I use:
rotatedImage = getToolkit().createImage(new MemoryImageSource(208, 270, rotatedArray, 0, 208));
This code only produce a black image on the P800, but if I run run it as a regular Java app everything works...
Any ideas?
Best regards,
Glenn
