Has anyone tried the FAR plugin? Comments?
FAR plugin
😕 call me stupid..., but what is the FAR plugin? what does it do?
FAR plugin allows accessing all SonyEricsson P800 drives from your PC using FAR file manager. You can perform all file operations just like with normal disks of your PC.
FAR manager is available from http:// www.rarlab.com. Just copy all files from the archive to "P800" subdirectory of your "FAR\Plugins" directory and restart FAR.
don't think I need it..
if u like to handle all your P800 files from PC, tryt using Remote P800, which I found it a real good software, u only run it on your P800 and PC while coonecting through craddle, and u have a full control on your mobile through your keyboad and mouse.
and if u want to transfer files from or to your mobilem there's MyP800 which should b installed with the Syc software came with your mobile.
both are easy and powerfull softwares
check site: http://www.mobileways.de
For managing your p800 drives from your PC you can also use PC File Manager from www.epocware.com
