I use 1.02 but the same problems exist like earlier version. Before the back-up finish about 95% something going wrong and say the archive ???? is in use or corrupted ?????.Wich archive ?. I change everything. Reinstall all soft both phone and pc-swite but nothing. How i found any way to back-up safe all my data?Also i try to copy my important files with Nokia Explorer but not luck. Any info welcoming.
<p><img SRC="rust.jpg" height=151 width=399>
<p>
I feel sorry cos I can not help you. What I wanna say is
The PCSuite for 9110 is the best thing.
It was very easy.
I can�t understand why Nokia has changed its working.
I have a 9110, and I have a 9210 too.
I think that a lot of things are much better on PCSuite for 9110.
For example, I had not have any aditional programs to synchro my 9110. PCsuite for 9110 has not given me any problem.
I want a PCSuite for 9210 like the PCSuite from 9110.
Regards.
This drives me crazy. I have about 300 contacts and you know my friend whats up if i loose them ? I make a new contact directory on MMC but i'm not sure if the best solution. May be the Nokia want sale MMC's because it's only way to make back up's ( safe ?). Also i think a problem with 9210 it's the small size of internal memory. Any way tnx for the answer.
Regards Chris
<p><img SRC="http//users.otenet.gr/~yaesu/pic9210/1ba1.jpg" height=150 width=66><p>
Hi!
Yes, I suggest you that you make one copy from your Contacts Directory to your MMC, I think this is the better way to have your Contacts Dir on to secure place.
And of course, the 9210 RAM memory is a great little shit...
Well, good luck..
Regards.
