i got an n-gage
5 replies · 2,089 views · Started 02 October 2003
this thing is pretty sweet.. 😊
it came with a tomb raider SD card in (because it is a pre-retail one, used for demonstrations), and it is amazing, full 3D..
Yes, I don't think i'll be making many calls on it, I haven't grasped the concept of doing that with it yet.
Only 5 days to go! 😊
its (relativily) thin and light, but its big, so u feel a little stupid with it pressed against your head (not as much as the o2 XDA 😊)
swapping cards is a little fiddly, but managable
i was pleasently suprised at the weight and thickness, it feels good to hold, it is not uncomfterable to use (a la 7650), and the bumps on the back give it a grippy feel
it took me about 4 mins to find how to get to the menu 😊
i thnk nokia is making a big GPRS/mobile web push with this, so one press on the menu button takes you to your online stuff (in a very nicely done menu on my network at least, there is a live news ticker at the bottom, giving you the latest headlines. from here you can access sport results, weather reports, news, download games/media - this menu will differ for different networks)
you need two presses of the menu button to take you to the normal symbian menu, which then acts as normal.
And you got a 12" Powerbook, nice! I've got the Rad 9000 1GHz 15" model from November.
Anyway back onto N-Gage, had a go in GameStation today but Tomb Raider crashed after 2 mins. Very cool port though and for some reason I actually like having the auto run feature, saves you having to hold forward down! Not something I'd buy though because of the current problems such as holding it side on to talk etc.
Hope it sells really well because if there is an updated model next year I'd love to snap it up then!
