Problem with Bemused!
1 replies · 1,320 views · Started 03 October 2003
Hi folks...
I hope you can help me...
I tryed to use bemused for my 3650, but it won�t do...
I set up a server at a Com-Port, so far no problems,
but when I startet Bemused, it said, that I can�t have more Blue-Tooth connections!
Is there a way to have more than one connection open?
Or can I at least prevent my Nokia-Suite Program from connection to my Phone?
double click the Mrouter icon on your systray then untick the ticked ports (normally port 4 and 5)
Then if u want to use your Mrouter tick the ports that u've unticked
