N-gage??? dust under screen
8 replies · 5,294 views · Started 03 October 2003
Ive just pre-ordered my n-gage and its getting delivered next week😃 . I can live with the way you talk on it and the way you have to take the back off and battery out to change games, but what I won't live with is if it develops dust under the screen like my 7650. Im used to the dust under my 7650 screen and ive had it cleaned twice, but I hate it when you've just paid �230 for a phone and after a month there is dust under the screen, it pisses me off.
basically for N-Gage you can just open the front cover and clean the screen from dust
and what i know is there must be dust under the screen as the cover is not fixed with the screen but with the removable front cover it should be easy to clean it up
Realy? I didnt know that the front cover was removable. Does this mean that the covers are xpress-on????
Originally posted by KROSS
...what I won't live with is if it develops dust under the screen like my 7650...
Where on earth do you keep your phones? My 7650 is nearly a year old and hasnt had dust problems at all. And I keep it in my pocket.
But I agree that it would be really annoying to have dust under screen...
(like on my old 3310, but thats so easy to clean)
