Trying out Psiloc ScreenSaver and when I use a filemanager utility which shows running apps, I get about 10 lists of ScreenSaver.
Anyone else have this happening to them?
Psiloc ScreenSaver listed many times in running apps
I looked and i have only one copy running, but it does seem to have a bug. I noticed that if you dont exit the config and just close the flip the jog dial stops working!
Yep - same happening to me.
just tried it now... the same applies😞
this should be a huge bug in their software, anybody tried getting in touch with Psiloc??
I uninstalled it practically as soon as I'd installed it.
It didn't work at all on my phone. All it kept doing was periodically turning the backlight on!
And in flip closed mode, it stopped pretty much everything working! The jog dial certainly didn't work, but the application menu didn't work either, which of course meant I couldn't turn the keylock on!
that might b because of other screensaver software were on, or not having enough memory in your device.
but the main problem that when it works, it starts several duplicate application in your RAM, which means there's something wrong whith its software, although I doubt that from a company like Psiloc, and the software is brand new launched 😕
I think there should b a time setting that sets the screensaver to work, which isn't working properly, causing the program to run several times in memory!
On this site http://www.psiloc.com/?id=prod&nrp=52 is a new version of Screen saver which dosen't lock the phone. In a next one or too days, lock screen will works even using P800 without flip. About this losing time people with this problem please write to [email][email protected][/email] with description how you do that. About this problem with opening more them one screen saver this is solved in a version 1.1.
WoW that was a good responsefrom the technical support guys, told ya .. it's a good company, and I like all there softwares.
wish I can spend more money to buy all of their P800 softwares 😛
