N-gage bluetooth
7 replies · 2,562 views · Started 06 October 2003
I currently have a 7650 and transfer files using infra-red, however, I should be recieving my n-gage in a couple of days and Im going to purchase a bluetooth headset and a usb bluetooth device for my p.c. I have read on the 7650 forum about compatability issues regarding usb bluetooth dongles and was wondering which one is the best and where i can buy it from???
If you are only going to transfer some files, you can do that with USB cable that comes with N-Gage. Bluetooth is needed for synchronasation. Pretty odd that you cant sync with USB cable. :\
I also want bluetooth for bemused, I was thinking about either the belkin adapter or the msi one, can't decide.
I have an N-Gage and I bought a Belkin Bluetooth USB Adapter, it works for both my 7650 and N-Gage... Previously, I was using infrared to connect to PC-Suite and takes me a long time to backup my device, but with my new bluetooth adapter it's really fast! 😊
Just remove MMC card before connecting the N-gage with the USB and you should be able to use the PC software without bluetooth.
I know that it doesn't work with the BT dongle that comes with the MS Bluetooth Cordless Desktop, but little does.
It works with the built-in BT of my Fujitsu Lifebook.
eh...i tried doesn't work... u mean u tried this b4 ?
