The latest version of Apple's iSync software 1.2.1 has improved support for Nokia series 60 devices and SE P800's. It now syncs Addresses, Address Pictures, Calender and To Do's. More details and download here.
Better Mac to Symbian Sync with iSync 1.2.1
Finally I can back-up more than telephone numbers! 😃
seems it no longer deletes entries that have been created by ms outlook while syncing to a pc. Also syncs to-do-lists!
So my new3650 still won't synch with 1.2.1. (I had high hopes this might actually fix it)
I'd been happily synching my phone via iSync for a while now and it had been working great. I was having problems with the phone randomly turning off so I went to cingular and they gave me a brand spanking new one. Now os x no longer lets me use my phone with iSync. If I "Setup Bluetooth Device" it picks up the phone fine. On the screen that says "select the services you want..." the item that says "Set up iSync to transfer contacts and events" is greyed out. I've tried resetting my phone with no luck. Several of my coworkers have the same phone and I can sync their phone without problems. I can use my phone to surf the web and I can transfer files back and forth no problem.
Is it possible that there is a new revision of the 3650 floating around now that no longer works with iSync. Anyone else having this trouble? Anyone know how to check for a version number anywhere on the phone?
-Tim
Me too. I can't get the "Set up isync to transfer contacts and events" option enabled on my p900 set up either. Thing is, it worked fine on my last p800. I've re-paired and sent files to the phone (my mac sees it OK it's just isynch that won;t see it) but no joy whatsoever
If anyone has found out how to resolve this please advise..
manythanks
j
