Can you only put .amr files in an MMS. Someone send me an MMS with a .wav file with an Sharp GX10 to my 3650. So i tried to send a .wav file back but i cant select .wav files for MMS. Only .amr files. Is that the only file type 3650 can send with MMS? Or is there a way to send .wav files?
Only .amr in MMS??
^^BUMP^^
Can't someone just give the answer???😕
I don't know how you can send *.wav files in MMS, but if you use RingtoneStudio you can send *.mid.....
Thanx for the answer, i'll try that.
