Clock Loosing Time On P800
9 replies · 2,465 views · Started 09 October 2003
My P800 is loosing about 30 minutes each day.
The time on the PC to which it syncs to is OK and the battery is always over 50%.
It does have a history of freezing a lot but this appears to have stopped now.
Anybody any clues.
try upgrading firmware.. that should help
otherwise, I suggest a clean format for internal memory 😞 then restoring your data!
30 minutes is bad.
The clock seems to drift by a few seconds a day,
I normally reset it every few weeks,
but with modern electronics I wouldn't expect that much variance in the chipsets.
Maybe you have some application that is interfering with the CTC interrupt?
havn't suffered from clock at all, time is always correct!
maybe cuz I connect it to my PC mst of the time, and it usually sync time from the PC, but even with regular use didn't face any problem.
as I suggested, guess upgrading firmware would solve this problem, cuz it's the only way he'll get a hardware reset.
have you got world mate installed? because that sometimes overwrites the time on the main phones clock. or ummmm, if you do have world mate installed, then you need to check you have the home country set correctly and the correct city too, other than that, try sitting in the corner of your room, and try foaming at the mouth.
even though, I don't think world mate would shorten day lenth to 23 hours and 30 minutes 😃
it's something related to the clock software in the mobile.
my suggestion would b either an internal format, or a firmware upgrade.
go for the format, I really like this option 😃
are you sure it doesn't happen after you sync it with the computer or connect to the cradle?
The sync process is supposed to sync you up with the computer's time as well.
If, for some reason, your PC timezone or your phone timezone don't match, you can have 30 minutes, 1 hour or a few hour difference after you sync up.
You can turn this feature on by putting the phone on the cradle and right clicking the P800 icon and selecting properties. Then, turn the checkbox off and see if that helps.
as mentioned, his PC time is correct, so I still believe it's from P800's clock..
Tal- u can check with your P800 dealer, he might help u with that
His PC time can *look* ok, whereas the timezone wouldn't match the phone's timezone! If that's the case, you wouldn't notice it any other way except when syncing the phone....
if u check time zones in ur PC, u'll find only 7 out of 74 has 30 minutes differ than the original 1 hour differ, so what percent has he to have his PC set to one of these 7 zones? 😛
