I looked everywhere cant find anything on mIRC Clients for 9290/9210 anyone seen anything?
Is it possible to get a IRC Client for Nokia 92x?
Yes and it's even freeware.
It's a simple one but works like a charm.
Of course you have to know the irc commands.
Download here
there will be no icon in extra, you'll have to run it from following folder: System\apps\Whois
Added it to the Software directory of this site.
Thank you i got it to work, one more question i got murcury instant messenger but it wont allow me to sign on AIM's network do you know why? Or if theres another program i should be using to sign on AIM?
I use IM+ full review on this site
The good thing about IM+ is that it uses direct connections which provides more stable and quicker connections.
Quick hint for this (or anyother app).
It may be slow, but don;t forget that the 9210's Java runtime can handle quite a few of the apps that aren't coded yet. For example, before WildPalm's speccy emulator, I was quite happily playing CHAOS and JET SET WILLY
through a Java Speccy Emulator running on the 9210. A touch slow, but both these games weren't time critical in the way that STARGLIDER is.
