As three coverage is so poor, how can i switch over the network to 02 video and picture service as ive heard this is more reliable.
Your help is much appreciated.
Go into phone menu and into settings.
Click on Network. Change registration preference to Manual.
Click 'Find New Network'.
Once the list comes up click on 02.
Then 'register'
Click on 'done'/
That should do it for you.
If you want to switch back to 3. Just click on Auto in the Network menu.
Hope it works for you
Its ok for you lot, I cant get 3 from inside my house( no I wont go out to make calls) and when I try the above I get vodaphone / Orange / T-Mobile........ and I'm in an area thats got good video coverage according to the homepage map . Away from home in poor signal areas if I reboot the phone it improves the signal, even to full strength.
