how to change time-slot value for ircomm.csy
0 replies · 2,330 views · Started 10 October 2003
Hi, when i test a VC++ Symbiam program using IR Serial (CSY) API in nokia 7650, i found that it only use one time-slot (time-slot 0) to discover other IRDA device.
It is not good because if other device only response other time-slot, they cannot be discovered.
How can i change it? i think i need to change in the ircomm.csy file. But how can i change the .csy file? i know it is a .dll file in fact, but how can i change it and recompile it?
thank you in advance!
lee jack
[email][email protected][/email]
