Hi all,
Got a 7650 the other day, and have noticed that when im on a call i get a
signal noise, the 1 you sometimes hear on speakers etc when your about to recieve a call or when its searching for the network? (beeping)
sos for not being to techy, but is there a way to stop this?
thanks
Jon
I just turned up the speaker volume to 'drown' it out.
[quote="Guest"]Hi all,
thanks
Jon[/quote]
i have the same problem.. :evil:
any tips?
Happens on every mobile I've used, it's just the signal interfereing with the speaker in the phone.
[quote="SwitchBlade"]Happens on every mobile I've used, it's just the signal interfereing with the speaker in the phone.[/quote]
yes... I see... but... it does NOT happen on every mobile for me.
I mean... if there's absolute silence you can hear it with almost all handsets. But... with 7650 and 9210 it is very loud, it gives me headache if I stay at phone very long... and having the girlfriend far away 500 KMs... I know what LONG calls mean. :-|
that noise last only 10-15sec.In nokia told me that is normal and there is nothing they can do :cry: .I think that is a problem with the armor of the earpiece..can we do anything?
