How to make wave for 9210?
3 replies · 1,729 views · Started 11 October 2003
First of all you'll need a decent sound-editting program... I don't know what kind of software you have, but on my Mac I use Cacophony.
first you select the part which you want to use, delete the rest of the track, and then 'normalize' the sound. normalizing pulls up the sound untill the hardest part is 0 db, this way the sound always has maximum sound.
Then when you save it, choose .wav, and reset the settings to:
-22,050 kHz,
-8 bit
-mono.
It's bigger than the files made with Nokia's multimedia converter, but the quality is much better this way.
Good luck! 😉
I think most people use Nero as their CD burner software
and with Nero there is a Nero Sound Wave Editor
with this program it lets you cut and compress in different compression of wave
and save it as the Unsound gives the setting
