Differnce between Memory Stick Duos (Normal, Pro, MagicGate ...)
6 replies · 15,424 views · Started 11 October 2003
Guys ..
I believe this info should b known and shared with all P800 owners:
I've found trhis on the memory stick website, which will give a great info about all memory stick duos features:
Memory Stick Duo (Normal)
Designed for use in ultra-compact and wearable devices for mobile applications.
For personal content and data only.
By attaching an adapter, it can also be used in products compatible with standard-size Memory Stick media.
Magic Gate Memory Stick Duo (White Colored)
For both copyright-protected content and personal content and data.
Magic Gate (High Speed Transfer Comatible) Memory Stick Duo (Dark Blue Colored)
Allows recording of copyright-protected content and high-speed data transfer, while maintaining a high level of compatibility with a wide range of products including compact mobile devices. By attaching an adapter, it can also be used in products compatible with standard-size Memory Stick media.
Memory Stick PRO Duo (While Colored, with Brown writing)
A compact media designed for mobile applications in the broadband era. Provides the great features and expandability of the Memory Stick PRO format, including the ability to record high-resolution moving images in real time. By attaching an adapter, it can also be used in products compatible with standard-size Memory Stick media.
I still find no explaing on big differences between all these kinds 😕 , anyone has more to add!?!?
info is from this site: http://www.memorystick.com/en/ms/variety.html#msduo
btw, I just bought 128 Magic Gate Duo (Dark Blue), which is the latest one 😃
Thanks for the info!
But I would be way more interested in the fact, if the Pro version works with the P800 and P900
Originally posted by NightSpider
hi handy....
so does the dark blue high-speed stick work ok with the p800?
it works well and makes ur P800 FAST and FURIOUS 😛
hAnDyGUY wrote:it works well and makes ur P800 FAST and FURIOUS 😛
i have a ms duo magic gate (dark blue device) 64MB card, and it's useable in my p800.
So i think that this answeres your question.
