when entering the pin code and security code at the beginning, do you find that when the flip is off, when you input a number, sometimes, it disappears? and then you have to enter it again? even though it registes the click and the astrix comes up? i do
disappearing digits
happened to me .. but only when I start entering digits the same time screen appears, cuz it looks that it has to check code stored on the SIM which take some time (half a second maybe), which will make consider whether the number was pressed or not!
once I entered the whole 4 ditits and nothing appeared on screen, then for a sudden 4 stars came up from nowhere 😛 , funny huh
