hi. would like help to find if app for 3650 nokia exists?
5 replies · 5,223 views · Started 12 October 2003
hi. english of mine is better becoming i imagine.
i look at app for change app buttons in phone app. want to start up other program instead starting up nokia default programs.
instance: i use button left on camera app only want to use instead for FExplorer app.
is such a program exist?
change the left/right softkey functions. In Settings/Phone, you can choose which buttons the softkeys control
But only as far as built-in applications go (i.e., you can't change them to any applications you have installed yourself).
Extended Profiles Pro from www.psiloc.com allows you to define the up, down, left and right joystick keys as applications, and it will allow you to set them to any installed programs.
