PsiNT Screen Saver - Problem
12 replies · 3,537 views · Started 12 October 2003
Hello all,
I have searched on this topic but cant find anything that may help so thought I would create a new topic.
I have version 1.10(0) of screen saver and its an excellent app. Problem is when someone sends me a text message, the little envelope symbol appears (to alert me of a new message) but then it stays there even once the text has been read.
Its just annoying because I keep thinking there's an unread message when there isnt.
The only way to get rid of it is to switch phone off then back on.
Anyone know how I can solve this?
Cheers,
Mike
I've ScreenSaver installed and I don't have that problem, so it might be a previous version bug or something. Update it and forget about it.
Thanks for that, I had a quick look before for new version but didnt find it. But i've found it now - Version 1.41(0)
This seems to have fixed the bug. Thanks,
Mike
I've been using version 1.3 for a long time now, and only just noticed that bug...
So I upgraded to 1.41, but now, with the "inbox status" option checked, messages are not shown when the screensaver is active. I just manage to see the icon in the bottom right as the screensaver finishes.
Anybody else had this??
Paul
ok after upgrading to version 1.41(0) it seemed to work fine for a day, but now I have same problem as "liverpool lad". the text message icon doesnt appear when theres an unread txt waiting.
Anyone have any other ideas?
i got the latest version from their website. but there seems to be a bug in the autolock. it can keylock but you can't use the option auto unlock or the " dont lock" command. does anyone have the same problem as mine?😞
I've asked support at Psiloc to have a look at it.
Generally what they do is fix it and post a new version, so give them a few days/ a week and check if there is an updated version on their website
Paul
Has anyone else noticed that screen saver really sucks up the battery power?
I have standby mode set to 1hour but it still drains the battery before the days out.
Just brought a new batt, will see if thats my problem when it arrives.
Mike.
Yes, it does consume battery power, also depends on the screensaver you choose (and/or the speed of the animation)
Some time back I got a 1200mah battery, and even with screensaver / reasonably heavy calling, it generally gets through to the end of the day.
Hello there. I have been having an unusual problem with my screensaver (being mine the v_1.20) and i have been using it on the Ngage (original ver.)
I have been using the gif animation screensaver, but up until now, as soon as 3 seconds pass that the screensaver gets loaded, it stops and returns to the normal screen. My gif is a 174x132 px and it weights around 52 KB. I first tried having the aniviewer on my phone, but since no expected results came out, i uninstalled the aniviewer and still i get no animated-gif screen saver that lasts more than 3 seconds.
Does anyone know why this might be happening? Mine's registered und all.
At least for now i will have to conform to use the spotlight option 😞
Greets.
