Can operator logos be uploaded to the n-gage?
7 replies · 2,632 views · Started 14 October 2003
Yes. Put the bitmap in c:\system\apps\phone\oplogo naming it using the country & operator identification codes.
Easiest way to do it, is to use a program like FExplorer where you can select an image and do "Options" -> "File" -> "Set as operator logo" & it does all the dirty work for you.
FExplorer is on http://www.gosymbian.com
you could also use opman which lets you use a photo you've taken aand choose a ertain part of it and use that as an op logo.
