hi,
is it possbile to install mp3 player on 3650? if so, does it gives quality sound just like playing on a PC or portable mp3 player??
hi,
Yes you can get an MP3 player. MP3GO is about the best one so I've heard.
But because of the 3650's mono speaker thry quality is not that good.
Actually I get better quality encoding as a low bitrate .wav file than I have when I played with .mp3 but that may just be the way I was encoding - to me the .mp3 were too loud and distorted.
Best
Will
Yeah - i think so too. MP3s doesnt sound as good.
But if you're still going for mp3s, make sure that program is mp3go. There's another program called mp3player which doesn't work so well. So bewarned.
While you are on the subject of music formats, question from a very newbie (so new that my phone hasn't arrived yet).
Has the 3650 got, or can you add WMA support?
Wouldn't mind using some of the 10,000 tracks from the PC without having to keep another copy in a different format.
There are no audio players for the 3650 that support the .wma format.
