Tracker version 3.1
0 replies · 2,999 views · Started 14 October 2003
The wait is over. Version 3 of Tracker arrives. Tracker is a real and fully customizeable desktop application. With the special skin system it looks and acts exactly like you want, offering you hundreds of unique functions and possibilities transforming your device from a simple organizer to a powerful and great looking handheld computer.
Please note: as Tracker behaviour is highly related to the currently used skin then some points in this user guide could not be valid for some skins. Current user guide is related to the default skin preinstalled with the application, but anyway this guide covers most of the application basics.
Tracker is used as a desktop. You can place any number of shortcuts to applications, documents, speed dials , speed sms, speed mms, webpage, etc on your desktop. You can drag and drop these shortcuts to any other place on the desktop or to the recycle bin. Icons could be native (native application icon, picture in contact) and fully customizeable (you can select any image in any size to use as a shortcut icon)
With one click on shortcut it becomes selected, with second click it starts.
If you want to start shortcut with single click you can enable "single click style action" options in Tracker settings.
When any shortcut becomes selected then short description about it is shown on the status label.
Note: some applications have only small icons (native), so if you've selected large application icon and this app doesn't have it, Tracker will ignore this option and will create a small icon instead.
Hint: recycle bin icon appears when you start dragging any icon.
Click for more detail
