Anybody bought a bluetooth hands-free yet for their n-gage?
I bought a skypower ezclip from expansys.com only to find that I got a error saying that the hands-free profile was not supported by the ezclip.
Looking to get another one - anybody know if the ericsson HBH-20 is compatible- expansys.com says it is but then they said the ezclip was as well.
Cheers
meiosis
heya meiosis i brought a jabra headset which had the same problem. As far as im aware the only headset that works with it is the nokia headset.
SAbz
ericsson HBH-20 isn't compatible either after feedback from expansys.com.
Is there anyway to get a symbian OS to recognise the headset profile?
Nokia HDW-2 & HS-3W work.
yeh, I've got to admit I'm trying to a be a bit cheepo here.
The HDW-2 & HS-3W retail at about 60-80 quid in the uk
The ezclip & ericsson HBH-20 retails at about 30 quid
meiosis
I've got a Jabra BT200 headset and it works with my N-gage.
It must be a new version, and the box must contain a blue sticker saying something like 'Compatible with Nokia 3650'. It seems that the BT200 suppors the handsfree profile instead of the headset profile that is not available for some NOkia phones.
Wat firmware version have you got joens? Ive got the 3650 compatiable bt200 and mine keeps coming up with the error.
SAbz
