N Gage Features, problems and remedies?
16 replies · 6,429 views · Started 14 October 2003
hi i'm new here and i'm going to buy an n gage soon..
if anyone could answer these questiosn i'll be eternally grateful..
will i be able to play .rm movies and mpg mpeg etc.? and watch them in full screen and sound?
and will it support 256 meg cards?
thanks..
Audio
heya audiophile,
.rm, .3gp and .mp4 are all supported on the phone. ive got simpsons episodes and allsorts on mine.
not sure about 256mb cards thou. theres a thread on here somewhere that has pictures of an nagage with a 512 card in it, not sure if its real thou.
SAbz
Originally posted by alvinpaul
i'm trying to get my hand on this MMC card, I think it should work 😃
keep us posted man! 😃
I have a 256mb Card in my n-gage it works fine 😊 I got 253mb full though 😞
erm i put some software on my n-gage qd and on mistake saved it to my phone memory instaed of mmci had like 10kb left after that it was saying to much memory delete some data so i went to delete some things i recived from bluetooth and it just crashed my phone saying memmroy full delete some data so i turned it off for 10 mins and then went back to turn it on and it wouldn't turn on it say nokia for like 10 seconds(and you know n-gage it takes like 3minutes of nokia logo thne it loads) and then it goes white and then restarts ithe process over and over and over what should i do
cheers if you can help plz plz
Rhyan i have posted in the forum the same problem but the only one that reply to me was GhostDog saying that i should go to a nokia service!!!!the diference is that i have enought space in the phone memory(i formated the n-gage 2 days ago).WOULD SOMEONE PLEASE HELP US!!!!
i hear there is a boot code (like a safe mode) ill try find it out
Rhyan to boot the phone in safe mode you have to press the edit(ABC) key at the start nokia logo and take it press till the phone start the normal screen.
However this don't work with me😞
TRY.
cheers ill keep posted and see if you can send it back to your place you baught it as faulty thats what i am going to do if don't fix cos it should'nt break cos of too much phone memory! but i will keep posted and see i i can help but ask the people you baught it from (i only had mine for aboot 2 weeks
Hi guys, saw your discussion about the ngage problems, yep, mine also experience the white screen problem. already returned to the store twice, hope they can do something about it. What they do is just reseting the phone by erasing all data on the ROM and reinstalling it, which doesn't solve the problem, it seems so unstable, after installing a few programs, it goes white screen and hangs. I like the phone but keep giving me this kind of problem. Have anyone found a way to solve this problem yet?
