Can someone please explain the Nokia Series 60 way of retrieving email.
Can I click a button and download my email in 1 step or must I download the headers first, then select what I want to download and then synchronise again (ie 2 steps).
Can I download just the first xxx bytes of a message?
Can I schedule email downloads?
Does the mail software support servers that require SMTP authentication?
If "no" is several or all the replies above, what other email packages would you recommend.
Thanks.
PS: What attachments are supported?
I think its easy if you just read the manual!
it's in the "have anyone noticed this?" thread
I have got the manual and have read it several times.
The questions I have asked above are either not clear in the manual or not mentioned at all!
i just tried to help..
never use my email through phone, so..
Can get all messages in one go.
Cannot download just first xxx bytes.
Cannot schedule.
Does support SMTP auth.
Attachments supported, but only formats the phone can handle can be accessed (.sis, jar., .amr, .jpg, .png, .bmp, etc.).
See also: http://www.reqwireless.com/emailviewer.html
