Heard someone at work they can shut down their PC with their Sony Ericsson T610.
Is this possible with the 3650?
Arni
Arni
Basicly it�s no problem!
If you find a programm to do this....
Bemused, for example has got a feature, that can shutdown your System.
But I don�t know if there are any other programs out there which can do this...
Bemused is awesome.Yes,it can shut down your PC.BTW:There are apps that will enable full access to your PC via BT or GPRS.Something like VNC.
http://www.simeda.com/activeviewer/ (yes, I'm a bit biased, I wrote it 😊 ).
Razvan
@ Ghost Dog: What is VNC??? What does ist do? And where can I get it? (Or a trial version??)
VNC can be found at http://www.realvnc.com/ or at the old site http://www.uk.research.att.com/vnc/. Our ActiveViewer uses VNC as its server.
Razvan
Thanks guys....big help! 😃
could you drazvan (or anybody) got activeviewer working over bluetooth?
if yes, how did you done that?
Yes, it works over Bluetooth. Search the forums for "Bluetooth dummy GPRS". It basically requires you to create a dummy GPRS connection that goes over Bluetooth (using Nokia's PC Suite). Send me an email at [email][email protected][/email] and I'll give you more details (I'm in a bit of a hurry now ...)
Razvan
