Psion Revo & p800
3 replies · 2,912 views · Started 15 August 2002
Does anyone know if the Psion Revo can send & *recieve* files via Ir to a p800 phone
thanks
Nigel
At a guess you wont be able to send files - they are different character sets (ASCII vs UNICODE), but contacts (individually) should be okay.
Is VCard and VCal compliant with any kind of IRDA device. That means that you can beam entries from your Revos Agenda,Todo & Contacts to any Palm,P800,7650,Pocket PC, Win2K etc that supports the standard. Yes even your favorite phone such as T68, Nokia 7110, Nokia 6210 and many many others.
plbeam from www.psiloc.com
will work with complete files according to their customer support.
Nigel
