installed applications
3 replies · 2,152 views · Started 15 October 2003
I've installed a few applications on my 9210i "C drive". I have just got a 64 MB mem card. Can I shift the installed applications to the "D drive". If so... how do I do it ?
Well it depends on wat kind of applications u have installed. Coz certain apps are integrated in the shell, & that wud b a prob. But if u only wnt to transfer games & stuff, jst use ur File Manager & Open up ur C:\System\apps copy d desired app folder to D:\system\apps (make sure thou dat ur show system file is turned on on the options menu 1st otherwise u wnt c it, dnt 4get to restart d file manager 1st) anyway, after doing so, sumtyms dat wnt jst do it coz sum apps have a separate data folder located at C:\system\data make sure to copy it to the same directory on the D:\
