Ngage Bugs
61 replies · 24,963 views · Started 15 October 2003
Firstly i owe an appology to Addario. i hav found my first bug.
I left sonic running in the background whilst making a fone call. When the call connected i found that i couldnt hear the person i was talkin to. As soon as i ended the game i could hear them.
Is there any solution to this? maybe in a new firmware?
Anyone else found any bugs?
SAbz
Second bug.
Ive had me fone nearly 2 weeks now and im beginning to see a potential problem.
Me fone switches itself off every now and again. Just a minute ago it switched off and every time i pressed the power button it just lit up. So i removed the battery and now its fine.
I havent got anything on it ATM so it cant be a software issue. Anyone got any ideas? Maybe a new firmware might help?
SAbz
wow i was just reading that sabz and i took my n gage out of my pocket and it was off for some reason but i do have other things in that pocket so there could be a chance the power button was pressed..
i also tried to make a couple of calls this morning but i couldnt hear anything but i think that it was just my phone company optus
also i think the battery indicator is faulty i'll be playing a game for a while it will still be full and i'll think oh great this battery isnt so bad..
then like half hour later its down to 5 then 4 but if i take out the battery and put it back in it gives me a more realistic reading..
but then again battery indicators have never been good in any devices... but i remember my friends old ericsson t20 had a cool feature where it would tell you how much standby and talk time was left on the batt. why dont nokia do this?
maybe this is not a ngage bug; a game bug... when Space Impact EvolutionX loading a new level press aome buttons. you`ll hear the default press button sound. after loading when the game starts when you press the fire button or any button n-gage plays the default button press sound again. not the game sounds. after a while it swiches to game sounds but for that time you hear the default sound.
I have found a bug. I have in the upper right hand side of my screen , no matter what the screen saver, little numbers....06043 and the other 3 chang often... I have tried everything but they are always there... any help#??????
Hi! Is firmware like the OS of a PC? where you can format and install again? or its a add-on software for the upgrade function for the phone? Where can I download firmware? any firmware for language upgrade? Cheers.
ceks
Hey
@omegaman
i think wat uve done is set your phone to tell you exactly what postal region your are in (sort of a gps system). I used to hav it on the 7650. Havent a clue how to stop it thou, maybe the intrucstion manual will have the answer.
@ceks
When you have your firmware upgraded, its just updates the software versions on your phone. You can get different firmwares for different languages but where i live (UK) the nokia centres wont update your fone to anything but english.
Firmware can not be downloaded, you will have to take your phone to a nokia service centre and get it flashed, I have version 3.30 and i dont know if theres an better version. Press *#0000# to find out what version u have.
How to format your N-GAGE.(C:,D: and Z: drives).
First make a backup using the memory option from the original program option on your N-GAGE.It will make a backup from your c:\ to your e:\backup\backup.arc.
dial *#7370#.
Additional, after you key in the *#7370# it will request a security code, if you never change before the code will be the nokia default security code 12345.
Note EVERYTHING will be lost even date and time!!!
Originally posted by sco2001
just turn cell info off omegaman, its under phone settings (at least it is on the 3650)
Hi , cannot find the option! Still need a little help, thanks
after i plug the usb cable to my pc, transfer some files and then unplug the cable, i can't see my mmc in ngage anymore. i need to restart it to see the content of mmc. Is it a bug?
Nah
it does that with mine sometimes. Usually if ya leave it for about a minute or so it shud recognise the mmc. Or plug the usb cable back it and remove it and it shud appear.
Hi guys! just remember to reboot or restart your Ngage when you have finish a long hours of games. If not your phone will nopt work properly. It will not be able to ring and vib when a phone call is in. Ngage is just like a com, need to be refresh memory.
Regards
ceks
Tools --> Settings --> Network settings --> Cell info display
Another bug I think.
I was listening to the radio, and after a few minutes it would switch to a new station.. The device was just sitting on the desk so I couldn't have been pressing anything
My old 8310 used to do that. A firmware upgrade solved the problem. Maybe itll solve the problem for you an all.
sometimes when my phone idles for too long and a call comes in, the whole phone hangs and it just keep on ringing and I have no way to answer it. a restart solved this problem.
considering iam getting an n gage for christmas i feel that using the mp3 player and radio would be a bad idea don't get me wrong i wouldnt mind using the radio as i already have an mp3 player but a lot of problems seem to be connected to the mp3 and radio like my friend he has had 2 n gages in the last month because of a certain music player system error i even tried to fix it using the reset code but that didn't work. Now my friend has just decided to leave it alone but everything else works fine apart from the mp3 function. Does anybody think that i should just forget using these functions or should i still use them also is their anyway to avoid these problems succesfully advice
PLEEEEASE!
PLEEEEASE!
What was that music player system error exactly? Please, be more specific.
well, my n-gage hasn't got these bugs 😃 It's new one. I bought it four days ago. Shopman said that almost all of the bugs are corrected 😃 Anyway I had to restart my n-gage... because there was o bug with the radio 😉
This is the second time my calendar entries have disappeared for no apparent reason.I've searched the forum it seems that I'm the only one that has encountered this problem.I'm really getting fed up,I'm even considering going back to my iPAQ.I'm running firmware version v 4.03
BTW: Does anyone know what is the latest firmware version available for the N-Gage.
GhostDog wrote:I'm even considering going back to my iPAQ
😮 :stupid: 😃
I have version 3.30 btw, and it's been perfectly stable this far (touch wood!).
Ghostdog...you dont happen to have Pro Rally installed..? If yes, uninstall it and check if it helps with your calendar problems. =)
I'm using N-gage for 4 days and already found 3 bugs... hope, that Symbian is more stable than devil-from-redmond's system...
1. Screenshot app + some games = hang or unstable work
2. Mp3 player: when started without headset, it informs: "Plug the headset or turn the loudspeaker on". I open the options menu, then I turn loudspeaker on, then press play, but nothing but white noise is comming out from speaker. It happened also once, while trying to "loudspeak" the radio.
3. The notepad app have some problems with refreshing screen while scrolling. Also, there are problems while scrolling the text:
[12|]
[13]
When the cursor was in indicated position, (' | '😉 but at the bottom of the screen, pressing the down arrow key didn't worked - cursor disappeared, in fact it moved before the '[' char in 13-th row.
Firmware is 4.03 (V 4.03; 26-11-2003; NEM-4)
Regards -- Spook.
