Should I delete Fexplorer from my 3650??
5 replies · 1,907 views · Started 16 October 2003
Just wondering...considering the many posts I have read with people having their phones die on them....
Is this program safe, and will it cause my phone to crash???
Please, someone give me an honest answer...
Imho don't delete FExplorer. It can only hurt your phone if you delete important system files. It's one of the greatest app for symbian phones. Mostly other apps (eg wildskins) crashes the phn.
Thanks...
basically, I only wanted it on my phone to change the operator logo...and really don't intend on doing very much else with it.....
But just wanted to be careful, because I really like this phone alot, and want to keep it operating good...
thanks again for you advice!
...and want to keep it operating good...
well, then you need FExplorer... 😉
If you don't wanna crash and have it hardreseted often, just don't try apps and jars, just install what you need. 😊
one more question...
is there such a thing as changing the operator logo TOO often....say, if I wanted to make a custom logo to match the color schemes and wallpapers, for example....
will this cause any potential problems???
thanks again for your help...
There are, but i donno what (maybe wildskins, smartlaunch). Simply changing the logo can't couse major probs if the pic's size, bbp etc. are correct.
Give this howto a chance.
