Profiles problem.
5 replies · 3,147 views · Started 16 October 2003
Does anyone knows how to disable my Flight Profiles. I'm unable to change it to normal mode. i tried to change profiles using profiles button but i won't work! Help me please.
how about trying to access it from the communicator side. Have you tried dat? Bt if evrythng else fails, i thnk a good hit on the Shift+Ctrl +F will do the job for u. I havnt encountered that kind of prob yet thou. I guess it depends on wat ver ur 92 is.😃
i've tried everything. failed.
How can i format my 9210? Is it possible for to setup again my Profile.sis file?
I'm really not sure!😕 😕
Help me please.
I don't think that you really need to format your device. Just try to exit the profile from the inside screen.
Anyway if you insist on formating, search in this forum, you can find detailed description on how to do that.
I'm really not sure what i'm going to do.
Finally , last night i try to format my 9210. Backup all my files to my pc then started to format. [shift+ctrl+f when you see the shaking hands after reboot your 9210]
After formatted i used to follow all the instructions given. Then my 9210 works as usual. My profile looks good too.
thanx guys for the advise and tips!
