N-Gage with HBH-35 problem
4 replies · 2,241 views · Started 16 October 2003
When the n-gage is connecting the HBH-35 Bluetooth handfree, if I got the call. only the HBH-35 be ring, the n-gage doesn't to ring, that cause missing call when the HBH-35 is away from my ear. 😡
That's the behaviour with a Bluetooth headset, I'm afraid.
If you also have the phone set on vibrate, then you'll at least have some indication you might sense without looking at the phone when you don't have the earpiece on.
This is the same way it operates with the corded headset plugged in. Thats they way headsets work, while in your ear you can hear, outside you can't.
Unplug the headset or turn it off(bluetooth) if you are not using it.
R.W.
Do you know that if I use the Nokia Bluetooth handfree with N-gage, when i got the call, will the N-gage to be ring?
