I know this is backwards from the normal question, but it would be nice to use my pc's cable modem connection to browse sites on my 3650 without wasting kb's through gprs. Anyone know of a way to make this happen?
3650 use PC internet connection
Yes - loads of info on this if you do a search.
Basically some browing applications will allow you to connect to your PC via BT and make use of the PC's internet connection.
Make a GPRS profile with nothing in it and call it BT.
Connect to the PC using BT Serial connection.
Try to surf on your phone, when it asks which GPRS profile to use select the BT one just created.
Best
Will
Does anybody have any experience about the same under linux?
can i use a ir port insteadt of bt.plz reply
