Cant delete file from beamed folder
1 replies · 2,148 views · Started 17 October 2003
I beamed a ebook to my phone.
Cant save it. If i click on the file it opens in mobireader.
No problem.
But now when i try to delete the file it goes though the normal process.
But the file is still there after i click yes delete!
Any one have an idea how i can get the file deleted?
all beamed files usually are save in c:\system\mail and gains different names.
u must check this folder and search every folder inside to look for that file, cuz if u don't save beamed files to any place of your own i'll get stuck in that folder forever.
I suggest using PCfilemanager from www.epocware.com it'll help u to explore your phon'e memory and track all these files
