pc software
5 replies · 2,201 views · Started 17 October 2003
Im in Australia and i didnt get the cd in the packaging so I dont have the driver to install the usb cable!!
Does anyone know where I can download the drive and software from?
THanks
Go back to the shop and demand the disk, i'm in Australia too and I got a disk so that has nothing to do with anything
There is no driver per se. You only have to connect your N-Gage to the PC via the USB cable and the PC should automatically detect it and it will appear as a separate hard disk drive.
The important thing that is included in the CD though, is the Nokia Audio Manager 3.0, so far the only version that can detect the N-Gage. It's a must if you want to create playlists for your MP3s when you transfer them to your N-Gage, but without it you can just drag and drop the MP3 files to the N-Gage using Windows Explorer (the MP3s will play in alphabetical order).
ok, i cant install my n-gage through usb, it reads it but it cant find any drivers that will work with it, not even storage devices. im on win98se and i dont have the cd
what drivers can i download that will work?
any help would be great, thanks
Ya best off searching the forum again for a decent answer as there are already quite a few threads regarding this issue, ill post a link to one if you have any trouble finding any, otherwise i would suggest upgrading your system to xp if possible as it makes life 10 times easier when it comes to things like this.
