hi there...is there anyway i can delete midi file i saved inside my phone or those midi that came with the phone?
midi
yes, you can use the recorder app to delete ones you have copied to your phone, the others are in ROM
Here's a good place for some -> http://asuwlink.uwyo.edu/~dwwilson/music.htm
Also -> http://www.sequinsbyeileen.com/midi.htm
