my phone wont send messages if the i memory in use is set to memory card. it works ok if it is on phone memory but it sais 'mesage sending failed' if it is on memory card. does anyone know how to fix this problem?
problems with text messages
Not only is the sms stored on the memory card but so are the settings.
You will probably find all your settings are in place for sms, mms, e-mail on your phones memory.
But when you switch to MMC memory the settings are mising.
You just need to copy them over 😊
Will
thanks
